Kindle Paperwhite 2nd Generation Screen Replacement
Выберете то, что вам нужно
  1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: шаг 1, изображение 1 из 1
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
    Be careful here. If you’re using something like a spudger or a longer bladed tool, it’s possible to slide it under the backlight/touch membrane and pull it up from the assembly. Use shallow movements and try your best to pry it up from the bezel only.
    Matt Adams - Ответить
  2. Kindle Paperwhite 2nd Generation Screen Replacement: шаг 2, изображение 1 из 2 Kindle Paperwhite 2nd Generation Screen Replacement: шаг 2, изображение 2 из 2
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Screen Replacement: шаг 3, изображение 1 из 1
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Screen Replacement: шаг 4, изображение 1 из 1
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
    This instruction set neglects to explain how the screen if removed how they show, still has the processor, battery, and other elements attached to the back side. These components must be removed from old screen back and placed on replacement one. IF there is a way to just do the screen without removing the components, these instructions do NOT show how to do that.
    DaveANYC - Ответить
Заключение
5 участников успешно повторили данное руководство.
Tyler Davis
Участник с: 09/15/16
1 574 Репутация
Автор 5 руководств
Команда
USF Tampa, Team 11-2, Blackwell Fall 2016 Участник USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 членов
Автор 7 руководств
2 Комментариев
My opening tool is orange. Will this still work for me?
FoxRunTime - Ответить
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 53
За всё время: 11,674
