Kindle Touch 3G Card Housing Replacement
Выберете то, что вам нужно
Видео обзор
  1. Kindle Touch 3G Card Housing Replacement, Back Cover: шаг 1, изображение 1 из 3 Kindle Touch 3G Card Housing Replacement, Back Cover: шаг 1, изображение 2 из 3 Kindle Touch 3G Card Housing Replacement, Back Cover: шаг 1, изображение 3 из 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
    Wear work gloves as the tool can easily slip and stab you in the hand.
    BRUCE - Ответить
    The clips aren't all the same; the side clips are slide-locks rather than press-locks.
    Use the Opening Tool to unclip the clips along the bottom edge. This will allow the lid to slide towards the top, releasing the side clips and allowing the lid to be lifted off.
    When reassembling, slide the lid upwards while pressing the sides to re-engage the side clips, then press the bottom edge to lock it into place.
    jimf - Ответить
  2. Kindle Touch 3G Card Housing Replacement: шаг 2, изображение 1 из 2 Kindle Touch 3G Card Housing Replacement: шаг 2, изображение 2 из 2
    • Gently lift the bottom and slide the panel off.
    There are four tabs on each side.The two nearest the top are open at the top, hence they slide out (back towards the power connector end.
    This is important in the reassembly stage:
    1. Align the back cover about 0.75 cm away from the top
    2. Hold the top half of the cover flat against the unit, and flex the cover away from the case a little at the bottom
    3. Slide the top and the first two clips parallel to the case
    4. snap the remaining bottom clips in place
    John Haywood - Ответить
  3. Kindle Touch 3G Card Housing Replacement, Battery: шаг 3, изображение 1 из 3 Kindle Touch 3G Card Housing Replacement, Battery: шаг 3, изображение 2 из 3 Kindle Touch 3G Card Housing Replacement, Battery: шаг 3, изображение 3 из 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch 3G Card Housing Replacement: шаг 4, изображение 1 из 3 Kindle Touch 3G Card Housing Replacement: шаг 4, изображение 2 из 3 Kindle Touch 3G Card Housing Replacement: шаг 4, изображение 3 из 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: шаг 5, изображение 1 из 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: шаг 5, изображение 2 из 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: шаг 5, изображение 3 из 3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
    The 3G model has an antenna connector near the top left on the underside.
    Chad Wade Day, Jr. - Ответить
Заключение
3 участников успешно повторили данное руководство.
Adam Yerly
Участник с: 01/20/15
1 933 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 19-5, Blackwell Winter 2015 Участник USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 членов
Автор 8 руководств
2 Комментариев
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
Curious_Guy_Threepwood - Ответить
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
Darren John de Lima -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 24
За последние 30 дней: 35
За всё время: 2,047
