Введение
If your Touch quickly runs out of battery or if it won’t charge, it may be time to replace the battery.
Запчасти
Детали не указаны.
With the small plastic opening tool, undo the plastic clips around the back lid.
Gently lift the bottom and pull as the rest of the plastic guides are on a track.
13 участников успешно повторили данное руководство.
Wear work gloves as the tool can easily slip and stab you in the hand.
BRUCE - Ответить
