Введение
Use this guide to properly replace your speakers.
Запчасти
Детали не указаны.
With the small plastic opening tool, undo the plastic clips around the back lid.
Gently lift the bottom and pull as the rest of the plastic guides are on a track.
Remove the six 4 mm screws in order to access the front plate. Use a Phillips #00 screwdriver.
Use a plastic opening tool to pry the top three sides of the bezel. Since there is glue under the bezel, gently pivot the face at the bottom off the Kindle and slide the clips out.
Use the pointy end of your Spudger to separate the Speaker's connector from the motherboard on both sides.
The speakers are held down solely with contact adhesive, so use your Spudger to pry them from the support board.
