Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Insert a plastic opening tool between the plastic panel shown on the device.
Use the tool to pry the plastic away from the device.
Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
Once the screws are removed, the back panel can slide off the device.
Remove the magnetic component with the magnetic head of the aluminum driver.
Инструмент, используемый на этом этапе:Tweezers$4.99-
Use tweezers to pinch in the sides of the vibrator cable and slide it out of its housing.
Один комментарий
OK, the procedure seems straightforward enough, but you say “no parts required” when you actually *do* need to buy the replacement parts for the pieces that are no longer functioning. Where can you buy these parts?
