Введение
In this guide, I will demonstrate how to replace their broken kitchen drawer mounts. This issue can be very common if drawers were not built with quality material when building the house. To get the material needed you can take in your broken track or mount into a hardware store and find the correct size. This is a quick and easy repair that will take little time and basic knowledge of repairs/tools.
Выберете то, что вам нужно
Remove all utensils from the drawer and remove the drawer from the slot.
Start removing the mounts and tracks by unscrewing them with your drill or screwdriver.
Take the track with the new mount attached and screw it into the existing hole using the new screws that came in the packaging.
After the track has one screw drilled, use a level to make sure your track is straight.
Drill the screws in either the existing holes or marked spots to hold the mount in place.
Now that your repair is done make sure your drawer is sliding smoothly if not you will need to remove it and clean the tracks. Another thing to look for is if the tracks are perfectly aligned if not you can go back in and fix them by following the same steps again.
Еще один человек закончил это руководство.
