Введение
If your mixer is only working on certain speeds, you might need to replace your circuit board. Don't worry, follow this guide on how to replace the circuit board.
Выберете то, что вам нужно
Using a Phillips #2 screwdriver, remove the 10 mm screw from the top of the back cover.
Using a Phillips #1 screwdriver, remove the 9.5 mm screw holding the circuit board in place.
Using pliers, remove the connections for each of the four wires connecting to the circuit board.
Grab the four wires away from the circuit board.
Tilt the board back to remove it.
If the board won't come out with some wiggling, you may need to loosen the two screws at the top of the control plate. Mark the top of the heads and loosen them 5 complete turns, without removing them completely. You may need to loosen the locking nuts.
3 участников успешно повторили данное руководство.
6 Комментариев
To protect the board, be sure to put heat-sink compound on the back of the new circuit (phase) board to ensure proper heat transfer to the housing.
Hi Chris I bought a secondhand kitchenaid mixer MODEL KSM75WH .. I was whipping meringue on a medium to high speed next thing there was an explosion black smoke coming from the machine, electrical burn smell…. Machine stopped and tripped my electricity.. can this be fixed …any idea what part needs to be replaced? Regards Savannah
hallo,
meine KidchenAid sagt seit heute nichts mehr. Es hat einmal geknallt und die Sicherung ist raus geflogen. Als ich den Elektronikdeckel hinten aufgeschraubt habe kam mir eine kleine Rolle auf einem Federdraht entgegen geflogen. Ich weiß nicht wo sie hingehört. Kann sie hier auf den Bildern nicht entdecken. Kann mir jemand sagen wo das Ding hingehört?
Danke Christian
