Введение
If you are worried about oil or grease leaking inside or out of your mixer, you might have to replace your gasket. This guide will show you how to do this.
Выберете то, что вам нужно
Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
Using the same flathead screwdriver, remove the two 28 mm locking screws.
Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
Use a butter knife or putty knife to remove grease from around the gasket.
Place grease in motor housing cover.
7 человек успешно провели ремонт по этому руководству.
2Комментарии к руководству
I got all the way to the last step of replacing the pin when i notice the mixer seemed to lock there in place and not move. What did i do wrong?
Dawn dawn6463@yahoo.com
