Введение
If your mixer won't spin or is noisy, follow our guide on how to replace the worm gear.
Выберете то, что вам нужно
Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
Using the same flathead screwdriver, remove the two 28 mm locking screws.
Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
Using a butter knife or putty knife, remove the grease from the gears.
Place the grease in motor housing cover.
Using a Phillips #2 screwdriver, remove the three 20 mm screws from the worm gear tower.
57 участников успешно повторили данное руководство.
28 Комментариев
Some corrections:
Step 1 -- Suggest (as the Service Manual does) using a flat-blade screwdriver and tap it with a light hammer to drive the drip ring off.
Step 2 -- the correct size pin punch is 5/32"
Step 3 -- Using two flat-blade screwdrivers, one on each side, pry off the planetary.
A plastic spudger is likely to break. Two points of leverage opposits each other distributes the load and prevents to the planetary and its shaft.
Step 11 -- The proper punch size is 3/32"
Steps 12 & 13 -- There is a washer on each side of the worm gear. Retain these and place one on each side off the grar when reassembling.
A link to the Service Manual:
Cheers Finkerbell,
Very helpful info, as was the main part of the guide.
Not sure what model number I was working on, but when I l lifted off the motor housing, there was still wires connected to the base.
Just be careful at this stage in case you have the same...
my model K5SS WH is the same as yours until step 5. It doesnt have the two bolts as shown in the picture for step 5 so i wasnt able to complete the repair. any suggestions.
This is the BEST! Thank you.
