Введение
This guide will illustrate how to replace the motor on the KitchenAid KHM512ER.
Выберете то, что вам нужно
Insert the back of a plastic opening tool into one of the beater holes
Apply force to pull the circular plastic part off.
If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
Use a Phillips 2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
Remove the bottom plastic piece using a plastic opening tool.
Using a Phillips 2 screwdriver, remove the three 20mm screws holding the motor assembly in place.
Use your hands to remove the motor assembly and circuit board.
Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
2 участников успешно повторили данное руководство.
