Введение
Removing the bowl screw cap is easy and doesn't take long. If the bowl doesn't stay in properly you might want to replace this part.
Выберете то, что вам нужно
Using a #2 Phillips screwdriver, remove the three 13mm screws holding the bowl screw cap on by rotating them counterclockwise.
Еще один человек закончил это руководство.
