KitchenAid KSM150PSER Carbon Brushes Replacement
Выберете то, что вам нужно
  1. KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: шаг 1, изображение 1 из 2 KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: шаг 1, изображение 2 из 2
    • Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
    • Remove brush cap by pulling it toward you.
    • The brushes are held in by springs and will fly out if removed too fast.
  2. KitchenAid KSM150PSER Carbon Brushes Replacement: шаг 2, изображение 1 из 1
    • Remove brush by pulling it toward you.
    • One corner of the brush is flattened. You can check which way the brush is oriented by shining a flashlight inside the hole.
Заключение
6 участников успешно повторили данное руководство.
Hayley Young
Участник с: 12/03/16
211 Репутация
1 руководство автора
Команда
Cal Poly, Team S2-G5, Livingston Winter 2018 Участник Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 членов
Автор 10 руководств
Один комментарий
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Amber Reimer - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 46
За последние 30 дней: 206
За всё время: 14,718
