Введение
If your device is not turning on, it may be the result of a faulty power cord. This guide demonstrates how to replace it.
Выберете то, что вам нужно
Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
The back cover is now free. Remove it by pulling back and up on the cover.
Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
Pull the trimband off the housing by grabbing each side and pulling it off the front.
Using a Phillips #2 screwdriver, remove the 12mm screw holding the grounding wire in place by rotating it counterclockwise.
Using pliers or tweezers, remove the connectors attached to the white and black wires.
Using a screwdriver, pull the cord string relief out of the mixer by putting it behind the cord and pulling away from the mixer until it is free.
Remove the cord from the mixer body.
