Выберете то, что вам нужно
Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
Remove the silver band.
Remove the four Phillips #2 screws located around the mixer where the band was removed.
Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
To remove the Bevel Gear, remove the snap ring wrapped around the base of the gear using Snap Ring pliers.
9 участников успешно повторили данное руководство.
14 Комментариев
I was thinking , - my god what a excelent tec. contribution material before watched your naked hands whit a lot of greasy spots
I’m from Ensenada Baja California “mother land of the internatiomal score baja off-road races“ and here we have a Doctor Simi drugstore’s where you can buy a pair of natural latex gloves whit or whitout powder s - m - l for less than one u.s. dollar. I buy gloves in monday’s because i pay 10 mexican pesos for it. “The little details son los que la cagan “
Need to know if after removing this bevel gear, does that allow the gear below it to be removed also? Because this is the one I need to replace.
Thanks
Once the Bevel Gear is removed you will see a pin that can be pushed out with a punch or small screw driver. That allows to you to remove the Worm Follower Gear. Keep you hand under the machine as the whole shaft can slide down. It’s pretty straight forward.
I removed the snap ring but my bevel gear is locked and I cannot remove it. I suspect the pin located below it is broken. Any suggestion? What can I do to replace both bevel and worm gears?
