Введение
This guide will provide a detailed step-by-step instruction guide on how to remove the power cord from the KitchenAid Professional 600.
Выберете то, что вам нужно
Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
Remove the silver band.
Remove the four Phillips #2 screws located around the mixer where the band was removed.
Locate the selector switch.
Remove the two Phillips #2 screws holding the selector switch in place.
Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
Remove the three Phillips #2 screws that connect the top portion of the mixer to the "neck" of the mixer.
Еще один человек закончил это руководство.
2 Комментариев
Any idea where I can buy the power cord itself?
