Введение
This manual is for repairing the USB port of your e-reader. It can be used for any type of e-reader, but some steps will be slightly different. This example uses the Kobo Glo HD. An iFixit set was used for this repair, together with a soldering station that enlarges the image under a camera. This is recommended because the parts are very small.
Выберете то, что вам нужно
All you have to do is lift the black locking arm that is keeping the ribbon cable in place. See picture.
Check the voltage of all six pins: if a pin shows no voltage level this probably means the pin is loose.
Use as much flux as possible (i.e. with the use of a flux marker).
A magnifying camera makes the job a lot easier.
Make sure that the pins are not touching each other.
Make sure that the e-reader functions properly before completely reassembling and closing it.
2 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
6 Комментариев
Hello guys, two of the pins on my reader are broken and I can't find the exact micro usb b model to buy the replacement.
Do you recommend a website to get it from?
Thanks a lot for your help
There was one on Ebay
