Введение
This guide will show you how to take out and replace the LCD screen on your camera.
Запчасти
Никакие детали не требуются.
  1. To start, remove the Philips #00 4.5 mm screws on both sides of the camera. On the bottom, there are three Philips #00 4.5 mm screws.  Two are for the front panel and one is for the back panel.  To remove the back panel, take out the screws indicated in the final picture of the sequence. On the bottom, there are three Philips #00 4.5 mm screws.  Two are for the front panel and one is for the back panel.  To remove the back panel, take out the screws indicated in the final picture of the sequence.
    • To start, remove the Philips #00 4.5 mm screws on both sides of the camera.
    • On the bottom, there are three Philips #00 4.5 mm screws. Two are for the front panel and one is for the back panel. To remove the back panel, take out the screws indicated in the final picture of the sequence.
  2. Once all the screws are out, remove the back panel. The front panel does not need to be removed for replacing the LCD or the Lens. To do this, start by removing the bottom of the panel.
    • Once all the screws are out, remove the back panel.
    • The front panel does not need to be removed for replacing the LCD or the Lens.
    • To do this, start by removing the bottom of the panel.
  3. Once the bottom part is unhooked, unhook the top, and the whole panel should come off. Be sure to gently pry the cover off.
    • Once the bottom part is unhooked, unhook the top, and the whole panel should come off.
      • Be sure to gently pry the cover off.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. In the top right hand corner of the inside of the camera, there is a Philips #00 4 mm screw that needs to be removed.
    • In the top right hand corner of the inside of the camera, there is a Philips #00 4 mm screw that needs to be removed.
  6. The next step is to remove the white ribbon on the upper right hand corner next to the LCD screen. This can be done with or without tweezers. The screen is still attached at the bottom, so do not take the screen off yet.
    • The next step is to remove the white ribbon on the upper right hand corner next to the LCD screen.
      • This can be done with or without tweezers.
    • The screen is still attached at the bottom, so do not take the screen off yet.
  7. Carefully pry the top portion of the screen from the camera. The screen is still attached to the camera via a yellow ribbon at the bottom of the camera. The screen is still attached to the camera via a yellow ribbon at the bottom of the camera.
    • Carefully pry the top portion of the screen from the camera.
    • The screen is still attached to the camera via a yellow ribbon at the bottom of the camera.
  8. To remove the screen completely, push down on the rectangular tab indicated in the picture. To remove the screen completely, push down on the rectangular tab indicated in the picture. To remove the screen completely, push down on the rectangular tab indicated in the picture.
    • To remove the screen completely, push down on the rectangular tab indicated in the picture.
  9. The LCD screen is now completely removed from the rest of the camera. The LCD screen is now completely removed from the rest of the camera.
    • The LCD screen is now completely removed from the rest of the camera.
Заключение
To reassemble your device, follow these instructions in reverse order. NOTE: be sure to put the internal screws on the inside and the external screws on the outside.
3 участников успешно повторили данное руководство.
Alyssa
Участник с: 12.04.2012
69 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 6-22, Amido Spring 2012 Member of Cal Poly, Team 6-22, Amido Spring 2012
CPSU-AMIDO-S12S6G22
4 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 8
За всё время: 2,224
