Введение
This guide will show you how to take out and replace the LCD screen on your camera.
Выберете то, что вам нужно
To start, remove the Philips #00 4.5 mm screws on both sides of the camera.
On the bottom, there are three Philips #00 4.5 mm screws. Two are for the front panel and one is for the back panel. To remove the back panel, take out the screws indicated in the final picture of the sequence.
Once all the screws are out, remove the back panel.
To do this, start by removing the bottom of the panel.
Once the bottom part is unhooked, unhook the top, and the whole panel should come off.
Be sure to gently pry the cover off.
In the top right hand corner of the inside of the camera, there is a Philips #00 4 mm screw that needs to be removed.
The next step is to remove the white ribbon on the upper right hand corner next to the LCD screen.
This can be done with or without tweezers.
To remove the screen completely, push down on the rectangular tab indicated in the picture.
To reassemble your device, follow these instructions in reverse order. NOTE: be sure to put the internal screws on the inside and the external screws on the outside.
3 участников успешно повторили данное руководство.
