Введение
Use this guide to replace your batteries.
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
2 человек успешно провели ремонт по этому руководству.
