Введение
Replacing the capacitor.
Запчасти
Никакие детали не требуются.
  1. Use your finger tip to slide battery cover door away from the center of the camera.
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
      • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Remove the old batteries.
    • Remove the old batteries.
    • Remove 7 screws from the outer case with a Phillips #00.
      • All screws are 4.45mm.
      • There are 2 screws on the port side.
      • There are 2 screws on starboard side.
      • There are 3 screws on the bottom.
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
    • To avoid an electric shock, do not to touch capacitor.
    • The capacitor is located underneath the lens.
    • It is held in place by 4 plastic snaps; it can be easily removed by pulling outward with your fingers.
    • Desolder points connecting capacitor to circuit board.
Заключение
Команда
Cal Poly, Team 26-19, Regan Spring 2010 Member of Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 7
За всё время: 3,842
