Введение
Use this guide to remove the back case.
Инструменты
Запчасти
Детали не указаны.
Position the camera with the bottom facing up.
With your finger, slide the battery cover in the direction of open arrow.
The battery cover will spring open, so be careful to lift it up gently.
Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
There are 2 on the left
There are 2 on the right
There are 3 on the bottom
Почти готово!
Заключение
