Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Position the camera with the bottom facing up.
Slide the battery cover in the direction of the arrow with your finger gently.
Remove the batteries
Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
2 on the left
2 on the right
3 on the bottom
Firmly grasp the back of the camera and pull the away the casing.
Keep the battery door open
Firmly grasp the front casing and pull away from the camera.
Orient the camera with the lens facing you.
Use a Phillips #00 screwdriver to remove the one 2.2mm screw on the plastic bridge.
Lift the plastic bridge off and place it to the side.
Grasp the capacitor, carefully remove it from its holder, and place it off to the side.
