Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Use this guide to remove and install the front case.
Запчасти
Детали не указаны.
  1. Position the camera with the bottom facing up. With your finger, slide the battery cover in the direction of open arrow. The battery cover will spring open, so be careful to lift it up gently.
    • Position the camera with the bottom facing up.
    • With your finger, slide the battery cover in the direction of open arrow.
    • The battery cover will spring open, so be careful to lift it up gently.
  2. Use a Phillips #00 screwdriver to remove the seven 4.5mm screws. There are 2 on the left There are 2 on the right
    • Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
    • There are 2 on the left
    • There are 2 on the right
    • There are 3 on the bottom
  3. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off.
    • Firmly grasp and pull back casing off.
  4. With battery door open, grasp the front case and remove it from the camera. With battery door open, grasp the front case and remove it from the camera. With battery door open, grasp the front case and remove it from the camera.
    • With battery door open, grasp the front case and remove it from the camera.
Заключение
2 участников успешно повторили данное руководство.
Dustin Rodgers
Участник с: 05.10.2010
65 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 7-51, Amido Fall 2010 Участник Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 2,741
