Введение
Use this guide to disassemble a Kodak EasyShare CD82, in order to remove and replace the LCD display screen.
Выберете то, что вам нужно
Remove the batteries and the memory card from the device.
Remove the 2 screws located at the bottom of the device.
Remove the 2 screws on the side, to the left of the camera lens.
Remove the 2 screws on the side, to the right of the camera lens.
Pry the casing from the device starting at the battery compartment and following the seem around the camera.
Remove the front panel from the device first, then remove the back panel.
Do not remove the LCD screen from the device once it becomes visible.
Flip the LCD screen away from the top of the device to reveal the ribbon cable.
This is water damage the has afflicted the camera.
Remove the 3 screws from the LCD screen holder.
Pry the screen holder from the circuit board connector.
Disconnect the logic board from the right side of the frame.
Remove the small ribbon cable that is connecting the button panel to the logic board, using a small pair of tweezers or hemostat.
Remove the screw on the top right side of the device.
Open the connector and move the black clip into the upward position, freeing the cable. Remove the LCD screen and the holder.
Follow these steps in reverse order to reassemble. The device should be fully functional upon completion.
2 участников успешно повторили данное руководство.
Один комментарий
Is there any repair for Kodak CD80 easy share camera…..as my camera is not working
