Введение
Replace unusable or damaged button.
Запчасти
Никакие детали не требуются.
  1. Open the battery cover.
    • Open the battery cover.
  2. Slide the orange latch sideways to eject the battery.
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery.
    • Remove 7 screws.
      • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
      • 4 (4.45mm) screws on the bottom of the camera.
      • 2 (2.95mm) screws on the left side of the camera.
    • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
    • Remove the rear camera casing.
    • Remove the front casing.
    • Remove the top panel screw (1x 4.37mm).
    • Remove the top panel.
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
    • Separate the inner casing from the tripod mount.
    • Gently pull the orange tab out of the circuit board.
    • Carefully flip the LCD panel to expose the central circuit board.
    • Remove the (1x 3.33mm) screw from the menu button panel .
    • Pull the second orange tab from the circuit board and remove the buttons.
Заключение
Michael
Участник с: 24.06.2010
63 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 2-8, Johann Summer 2010 Member of Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 членов
Автор 8 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 1,203
