Запчасти
Никакие детали не требуются.
  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  6. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
  7. Remove screws from front silver panel. Remove screws from front silver panel. Remove screws from front silver panel.
    • Remove screws from front silver panel.
  8. Lift up ribbon cable fastener with blue plastic opening tool. Gently pull out lens. Gently pull out lens.
    • Lift up ribbon cable fastener with blue plastic opening tool.
    • Gently pull out lens.
  9. To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
    • To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
Заключение
Brian
Участник с: 13.03.2014
252 Репутация
Автор 2 руководств
Команда
New Mexico State, Team 1-2, Easley Spring 2014 Member of New Mexico State, Team 1-2, Easley Spring 2014
NMSU-EASLEY-S14S1G2
5 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 154
