Введение
Removal and replacement of the buttons from your Kodak EasyShare M381 can be simple and easy. You can also use this guide for simply cleaning your camera buttons if they have a weak connection. Be sure to turn the camera off and remove the batteries before beginning this repair.
Выберете то, что вам нужно
First, press in and slide forward the battery latch as indicated by the arrow.
Press down on battery until you hear a click and release it. Battery should easily slide out.
Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
