Введение
This guide shows how to replace a broken LCD on a C183. It is not a difficult job, however, most cameras open from the back case first, this one opens from the front first.
  1. Remove the two screws from the right hand side Remove the two screws from the left hand side Remove the three screws from the bottom.
    • Remove the two screws from the right hand side
    • Remove the two screws from the left hand side
    • Remove the three screws from the bottom.
    • All the screws on this camera are the same size. No need to mark them by position.
  2. Open the battery compartment and start carefully to separate the front and back half of the camera. On this camera the front half will come of first. In the top left corner is one screw that will have to be removed. It holds the back cover to the body of the camera. Once that screw is removed, the camera separates easy.
    • Open the battery compartment and start carefully to separate the front and back half of the camera. On this camera the front half will come of first.
    • In the top left corner is one screw that will have to be removed. It holds the back cover to the body of the camera.
    • Once that screw is removed, the camera separates easy.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Fold the LCD from the top downward. DO NOT try to remove the LCD, it is still attached. Obviously this camera has had water damage. Remove the Kapton tape from the top of the camera. you will have to de-solder the battery frame on one point.
    • Fold the LCD from the top downward. DO NOT try to remove the LCD, it is still attached. Obviously this camera has had water damage.
    • Remove the Kapton tape from the top of the camera.
    • you will have to de-solder the battery frame on one point.
  5. Remove the tape Remove the single screw. You can disconnect the ribbon cable, by carefully pulling on the end. I opted to leave it connected to minimize the risk of tearing the fragile cable. It is possible to just move the frame out of the way.
    • Remove the tape
    • Remove the single screw.
    • You can disconnect the ribbon cable, by carefully pulling on the end. I opted to leave it connected to minimize the risk of tearing the fragile cable. It is possible to just move the frame out of the way.
  6. Lift the LCD frame slightly up and fold the black clip gently to the back. This will loosen the ribbon cable and lets your remove the LCD. Insert the ribbon cable of the new LCD. there will be a solid white stripe on the cable. Insert the cable as shown, close the connector.
    • Lift the LCD frame slightly up and fold the black clip gently to the back.
    • This will loosen the ribbon cable and lets your remove the LCD.
    • Insert the ribbon cable of the new LCD. there will be a solid white stripe on the cable. Insert the cable as shown, close the connector.
Заключение
oldturkey03
Участник с: 29.09.2010
571 761 Репутация
Автор 101 руководств
Команда
OTS Member of OTS
Business
1 член
Автор 126 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 8
За всё время: 1,890
