Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution
Выберете то, что вам нужно
  1. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Identify the problem: шаг 1, изображение 1 из 1
    • Identify that your printer is jammed. This is usually indicated by the paper light blinking quickly.
  2. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Removing the paper tray: шаг 2, изображение 1 из 1
    • Gently pull the paper tray out of the printing dock to remove it.
    • When the paper tray is empty, the paper light should glow a steady amber.
  3. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Disconnecting the power adapter: шаг 3, изображение 1 из 2 Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Disconnecting the power adapter: шаг 3, изображение 2 из 2
    • Disconnect the power adapter from the printer for 10 seconds, and then reconnect the cord.
    • On some models, you may have to press the power button in addition to plugging in the power adapter.
    • Wait for the printer to initialize in order for the jammed paper to exit from the back side.
    • Notice: Carefully remove the paper if it does not automatically eject.
  4. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Removing the paper supply: шаг 4, изображение 1 из 1
    • With the paper tray in hand, open the front lid in order to gain access to the paper supply.
    • Take hold of the paper bundle, and carefully “fan” it to keep the sheets from sticking together.
  5. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Reload and reinstall the paper tray: шаг 5, изображение 1 из 1
    • Reload the paper tray by sliding the paper bundle back into the intended slot, and then close the lid.
    • Next, slide the paper tray in the printer tray slot until the tray locks into place.
    • To ensure the paper tray fits squarely on the printer dock, make sure to keep the paper tray cover all the way open while installing.
    • Press the power or print button to clear the paper error and resume printing.
Заключение
Henry Ta
Участник с: 10/13/16
101 Репутация
1 руководство автора
Команда
University of Maine, Team 1-6, Diaz Fall 2016 Участник University of Maine, Team 1-6, Diaz Fall 2016
UMAINE-DIAZ-F16S1G6
2 членов
Автор 1 руководств
Один комментарий
My doc is only print half of pic what can ido
Amy Winfree - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 18
За последние 30 дней: 83
За всё время: 3,143
