Выберете то, что вам нужно
Open the battery cover and remove batteries from the camera if any are inserted.
Инструмент, используемый на этом этапе:Phillips #00 Screwdriver$5.49
Use a 00 Phillips-Head screwdriver to remove screws:
Remove the 3 mm screws from the camera
Four (4) screws are in the bottom of the device
Four (4) screws are inside the battery cover
Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
Two (2) screws are located in the left side of the device
Two (2) screws are locatecd in the right side of the device
Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
Еще один человек закончил это руководство.
