Kodak Easyshare Z981 LCD Screen Replacement
Выберете то, что вам нужно
  1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: шаг 1, изображение 1 из 2 Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: шаг 1, изображение 2 из 2
    • Open the battery cover and remove batteries from the camera if any are inserted.
    • Use a 00 Phillips-Head screwdriver to remove screws:
    • Remove the 3 mm screws from the camera
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  2. Kodak Easyshare Z981 LCD Screen Replacement: шаг 3, изображение 1 из 1
    • Start from a corner and gently remove the cover.
    • The cover will easily lift off, so not much pressure is required.
    • Make sure to gently remove the bottom cover in order to avoid breaking the plastic.
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  3. Kodak Easyshare Z981 LCD Screen Replacement: шаг 5, изображение 1 из 2 Kodak Easyshare Z981 LCD Screen Replacement: шаг 5, изображение 2 из 2
    • Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
    • Be gentle while removing the cover, to avoid cracking the case
  4. Kodak Easyshare Z981 LCD Screen Replacement: шаг 6, изображение 1 из 2 Kodak Easyshare Z981 LCD Screen Replacement: шаг 6, изображение 2 из 2
    • Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
    • Gently lift up the metal brace and use a pair to disconnect the ribbon cable connecter
    • Use Tweezers to disconnect the ribbon cable connector.
    • Once disconnected remove the screen brace from the circuit board
    • Use extreme caution when removing the LCD brace pulling the brace may tear the cable
Заключение
Еще один человек закончил это руководство.
Daniel Ramirez
Участник с: 03/03/15
152 Репутация
1 руководство автора
Команда
Sam Houston State, Team 13-6, Blackburne Winter 2015 Участник Sam Houston State, Team 13-6, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S13G6
3 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 530
