Kodak Easyshare Z981 Top Shutter Button Replacement
Выберете то, что вам нужно
  1. Kodak Easyshare Z981 Top Shutter Button Replacement, Top Shutter Button: шаг 1, изображение 1 из 2 Kodak Easyshare Z981 Top Shutter Button Replacement, Top Shutter Button: шаг 1, изображение 2 из 2
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
    • Remove all screws on the outside of the camera with a 00 Phillips-Head screwdriver
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) screws on the bottom of the camera
    • Four (4) screws inside the battery cover
  2. Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 3, изображение 1 из 3 Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 3, изображение 2 из 3 Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 3, изображение 3 из 3
    • Detach the bottom part of the camera by removing four (4) 3mm screws
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  3. Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 4, изображение 1 из 2 Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 4, изображение 2 из 2
    • Use the Plastic Opening Tool to put light pressure and remove the back cover of the camera
    • Be gentle when removing the back cover
    • Unscrew the four (4) 3mm screws to remove the screen from the circuit board
    • Use Tweezers to delicately detach the ribbon cable
    • Carefully remove the screen brace from the circuit board
  4. Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 6, изображение 1 из 3 Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 6, изображение 2 из 3 Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 6, изображение 3 из 3
    • Remove the two (2) 3mm screws from inside flash compartment
    • Remove one (1) 3mm screw from the circuit board
    • Use the Tweezers to detach the ribbon cable connecter from the circuit board
    • Use the Plastic Opening Tool to gently apply pressure on the top of the camera and remove the upper portion
  5. Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 8, изображение 1 из 3 Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 8, изображение 2 из 3 Kodak Easyshare Z981 Top Shutter Button Replacement: шаг 8, изображение 3 из 3
    • Remove the four (4) 3mm screws from the circuit board directly underneath the shutter button and gently move the circuit board aside
    • Lift up the metal clamp
    • Use caution when removing the circuit board to avoid tearing the wires connected
    • Pull the small brace on top of the shutter button
    • Using the Tweezers, gently remove the shutter button
Заключение
Matthew Myers
Участник с: 03/03/15
219 Репутация
1 руководство автора
Команда
Sam Houston State, Team 13-6, Blackburne Winter 2015 Участник Sam Houston State, Team 13-6, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S13G6
3 членов
Автор 9 руководств
Один комментарий
looking for z981 bottom wrist grip jwkcm1978@hotmail.com
jwkcm1978 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 589
