Введение
Back Cover Teardown guide must be used first to get inside the camera. Later, soldering guides will be used.
Запчасти
Никакие детали не требуются.
  1. Remove the two 6.2mm Phillips screws on both sides of camera's back cover. Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Turn camera so the bottom is facing up and the front is facing away.
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Have the back of the camera facing up.
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
  5. The capacitor is located at the bottom center of the camera.
    • The capacitor is located at the bottom center of the camera.
  6. Desolder the two connections at the top of the flash capacitor.
Заключение
Michelle
Участник с: 04.04.2011
86 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 25-28, Garner Spring 2011 Member of Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 11
За всё время: 1,814
