Введение
The “Free-Stand” button enables the stroller to fold into a freestanding, compact position. Sometimes the button can get stuck and requires simple internal repair. This guide will walk you through that process.
Выберете то, что вам нужно
Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
