Выберете то, что вам нужно
Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
Remove the single black Phillips size 0 10mm length screw on the back of the machine.
Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
1 Комментарий к руководству
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
