Введение
If you need to disassemble your Krups CafeExpress FMA110 for repair or spare parts, follow this disassembly guide. Repairs could include a burnt-out heating element, faulty wire connection, ripped tubing, burnt-out thermal fuses, broken temperature switch, etc.
Be sure the device is unplugged before you begin disassembly to avoid burning or electrocuting yourself, which can cause serious injury.
Steps 4 and 6 require pulling silicon tubing off of the device. The tubing can rip easily, so be careful. The opening tools can help with these steps.
Выберете то, что вам нужно
Using the Phillips #1 screwdriver, remove the four 13.8 mm screws on the bottom of the device.
Remove the metal plate.
Using the Phillips #1 screwdriver, remove the two 16.7 mm screws to release the power cable.
Pinch the clamps around the thinner part of the silicon tubing and slide them towards the corner of the tube.
Pinch the clamps around the thicker part of the silicon tubing and slide them towards the corner of the tube.
Using the Phillips #1 screwdriver, remove the three 13.8 mm screws towards the back of the base.
Loosen the white ring from the switch and squeeze it to slide it through the opening in the base.
Using the Phillips #1 screwdriver, remove the three 15.8 mm screws to release the inner components from the plastic base.
Using the Phillips #1 screwdriver, remove the two 11.5 mm screws on either side of the horizontal metal bracket.
Remove the horizontal bracket to separate the heating element and wires from the hot plate.
Using the Phillips #1 screwdriver, remove the two 7.6 mm screws and remove the thermal switch.
Using the Phillips #1 screwdriver, remove the two 9.9 mm screws from the hot plate.
Separate the hot plate from its frame.
