Krups F203 Coffee Grinder Base Plate Replacement
Выберете то, что вам нужно
  1. Krups F203 Coffee Grinder Base Plate Replacement, Base Plate: шаг 1, изображение 1 из 1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Base Plate Replacement: шаг 2, изображение 1 из 3 Krups F203 Coffee Grinder Base Plate Replacement: шаг 2, изображение 2 из 3 Krups F203 Coffee Grinder Base Plate Replacement: шаг 2, изображение 3 из 3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Base Plate Replacement: шаг 3, изображение 1 из 2 Krups F203 Coffee Grinder Base Plate Replacement: шаг 3, изображение 2 из 2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
Заключение
9 участников успешно повторили данное руководство.
Brian Wolfskill
Участник с: 10/23/14
420 Репутация
1 руководство автора
Команда
Baylor, Team 4-2, Williams Fall 2014 Участник Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 членов
Автор 8 руководств
10 Комментариев
Thanks! I was able to repair my broken cord.
wdswaim - Ответить
I'mworking on it as we write .
jerry - Ответить
Does anyone have a video tutorial explaining how the heck one removes the base?? I bought a spudger and it still doesn't help. It is awfully hard to loosen up.. I kept trying and trying but I stopped cause I'm concerned I might break the clips and the outside which the plastic is starting to stretch.. the clips are starting to lose their shape as well and worried I might break the spudger... Thanks
NeonAera - Ответить
I am having the same experience as NeonAera posted. I could clear 2 of the 4 clips, but not the others and getting the same issue of distorting the outside wall of the base , if I continue to try and pry the clips with the spudger. Thanks
Steve Ferrill - Ответить
We had a jammed . I disassembled according to the guide, scraped out the rust I found, lubricated with WD40 and reassembled. Went from not moving to working great. I broke all 4 tabs (guess I lack patience…) but gorilla taped it back together and it's totally solid.
Wade Brainerd - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 13
За последние 30 дней: 53
За всё время: 11,263
