Введение
This guide will show you how to replace your Kurio's battery.
Запчасти
Никакие детали не требуются.
  1. Make sure to open the back cover easily using the plastic opening tool.
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Remove back cover by prying away from the device. The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides. Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
  5. After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
    • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
  6. Use the plastic opening tool to remove the battery from its place.
    • Use the plastic opening tool to remove the battery from its place.
    • The battery is glued into the device. So try removing it gently.
  7. Remove the two wires using soldering tool to detach your bad battery from the device .
    • Remove the two wires using soldering tool to detach your bad battery from the device .
    • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
    • For more information on how to solder and desolder the wire Click here
Заключение
2 участников успешно повторили данное руководство.
Khalid AlTamimi
Участник с: 21.01.2015
251 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 6-5, Brown Winter 2015 Member of USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 членов
Автор 10 руководств
Один комментарий
do you know where to buy a replacement battery ?
Phil Bowring - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 6
За всё время: 1,265
