Введение
This guide will show you how to replace your Kurio's battery.
Выберете то, что вам нужно
Remove back cover by prying away from the device.
The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
Remove the two wires using soldering tool to detach your bad battery from the device .
3 участников успешно повторили данное руководство.
2 Комментариев
do you know where to buy a replacement battery ?
Any idea where I can purchase a replacement battery?
