Введение
This guide will show you how to replace your front & back camera of your Kurio Touch 4S
Выберете то, что вам нужно
Make sure to open the back cover easily using the plastic opening tool.
To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
Separate the two halves of your Kurio Touch 4S.
Use the Tweezers to detach the front and back camera from its place.
Еще один человек закончил это руководство.
