Выберете то, что вам нужно
Make sure to open the back cover easily using the plastic opening tool.
To remove the battery, make sure the four 5mm Phillips screws on each side of your device is open using the Phillips #1 Screwdriver
After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
After you remove your four 5mm Philips screws use your plastic opening tool to help you open the plastic cover of your device.
Detach all the wire that are connected to the motherboard.
Detach the camera module and other components that are attached to the motherboard.
Use tweezers to hold the power button and gently lift it up.
Replace the old power button with the new one.
Еще один человек закончил это руководство.
