Введение
This guide will show you how to replace your broken screen.
Выберете то, что вам нужно
To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Philips#1 Screwdriver.
After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
Detach all the wire that are connected to the motherboard.
Also remove the camera module and other components that are attached to the motherboard.
Use the soldering tool to remove the wire that is attached to the screen & the motherboard.
3 участников успешно повторили данное руководство.
