Выберете то, что вам нужно
Make sure to open the back cover easily using the plastic opening tool.
To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver
After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
Еще один человек закончил это руководство.
