Введение
Follow this guide to remove or replace the on/off switch on a 2014 Kushlan cement mixer model 600DDS.
To prevent electric shock, leave the device unplugged for 20 minutes to allow the capacitor to discharge before you begin.
Выберете то, что вам нужно
Use a 13 mm socket to remove the two bolts securing the motor cover to the frame.
Use a Phillips screwdriver to remove the four screws securing the electrical panel.
Use a pair of needle-nose pliers to disconnect the four wires from the back of the on/off switch.
Use a flathead screwdriver to press the sides of the on/off switch through the opening in the electrical box.
