Kyocera Event MicroSD Card Replacement
  1. Kyocera Event MicroSD Card Replacement, Battery: шаг 1, изображение 1 из 3 Kyocera Event MicroSD Card Replacement, Battery: шаг 1, изображение 2 из 3 Kyocera Event MicroSD Card Replacement, Battery: шаг 1, изображение 3 из 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event MicroSD Card Replacement: шаг 2, изображение 1 из 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event MicroSD Card Replacement, Locate the SIM card: шаг 3, изображение 1 из 1
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event MicroSD Card Replacement, Open slot and remove card: шаг 4, изображение 1 из 2 Kyocera Event MicroSD Card Replacement, Open slot and remove card: шаг 4, изображение 2 из 2
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
Заключение
Еще один человек закончил это руководство.
graysonmensah
Участник с: 02/13/15
22 Репутация
1 руководство автора
Команда
Ohio State, Team 1-4, Michaels Spring 2015 Участник Ohio State, Team 1-4, Michaels Spring 2015
OSU-MICHAELS-S15S1G4
3 членов
Автор 4 руководств
3 Комментариев
That's the micro SD slot. That's not for a SIM card.
Carl Jr - Ответить
What if there's no metal cover?
Michael ansley - Ответить
That's for the sd card not the sim card
gasparesparza9 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 3,043
