Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
In order to reach the motherboard of the mobile phone, the back assembly needs to be removed.
Запчасти
Детали не указаны.
  1. Locate the small notch on the bottom right side of the phone. To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off. The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. The SIM card slot can be seen in the middle left of the photograph.
    • The SIM card slot can be seen in the middle left of the photograph.
  5. The SD card slot can be opened and closed, as depicted by the tool. The SD card itself slides into and out of the metal cover.
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
  6. Remove seven of the 4.9mm tri-head screws. Keep them in a secure location. Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
    • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
  7. Pry the back assembly away from the body on all four sides of the phone. Start prying at the top and work around. Remove the buttons for the volume and power-this will allow for easier disassembly.
    • Pry the back assembly away from the body on all four sides of the phone.
    • Start prying at the top and work around.
    • Remove the buttons for the volume and power-this will allow for easier disassembly.
    • The back assembly is firmly attached to the body of the phone so removing it will require some force.
Заключение
Philip
Участник с: 13.02.2015
7 Репутация
1 руководство автора
Команда
Ohio State, Team 1-4, Michaels Spring 2015 Участник Ohio State, Team 1-4, Michaels Spring 2015
OSU-MICHAELS-S15S1G4
3 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 558
