Введение
This guide will teach you how to remove the back of the phone in order to gain access to the battery. Afterwards, we will instruct you on how to safely remove the battery from the device, and install a new one.
Выберете то, что вам нужно
Look for a small indentation on the bottom of the phone.
Insert the plastic opening tool into the indentation and lift off the back casing.
The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
Place the plastic opening tool in the indentation and lift the battery out of the socket.
5 участников успешно повторили данное руководство.
