Введение
Remove the camera button and replace it.
Выберете то, что вам нужно
Look for a small indentation on the bottom of the phone.
Insert the plastic opening tool into the indentation and lift off the back casing.
The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
Place the plastic opening tool in the indentation and lift the battery out of the socket.
Locate the screws holding the trim which are the four side screws on each corner.
Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
Locate the clasps holding the trim in place.
You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
Инструмент, используемый на этом этапе:Tweezers$4.99
Now that you have taken apart the trim, the camera button should be easily removable.
Locate the camera button. When looking at the back side (battery side), the camera button will be on the left side.
Take the camera button out with tweezers.
