Введение
Sometimes the lock button gets stuck and needs to be replaced this guide will show you how to replace/ fix it.
Выберете то, что вам нужно
Look for a small indentation on the bottom of the phone.
Insert the plastic opening tool into the indentation and lift off the back casing.
The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
Place the plastic opening tool in the indentation and lift the battery out of the socket.
Locate the screws holding the trim which are the four side screws on each corner.
Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
Locate the clasps holding the trim in place.
You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
Once you have taken the trim apart, the lock button will be easily removable.
The lock button is located on the top of the phone.
Take the tweezers and remove the lock button.
