Введение
The Kyvol Cybovac L20 has a Main Brush that may stop working over time from use. You should try cleaning off the main brush if it stops working. If that doesn't work, then you will need to replace it. Before doing any work on it, the Kyvol Cybovac L20 should be turned off.
Почти готово!
Заключение
